Hello,
I want to know, wich is the best welding filler material to weld wear resistant sheet.
The material base is wear resistant sheet like HB-400 or HB -450.
Thank you
Hi,
We remaind you that this website is french speaking.
Please, can you tell us the welding process and the grade of the wear resistant sheet
Thank you
Best regard
hi,
I know that is french speaking
But i am sorry, i am from spain and i don't know french.
Anyway, i will use the translator and the next messages will be in french.
Best regards.
Hi leihotikan,
OK we understand the problem...
We do not speak Spanish.
And it is a good exercise for us to speak and write in English !
Can you tell us the welding process and the grade of the wear resistant sheet ?
Best regard.
Hi,
For example:
C: 0,21%
Mn: 1.70%
Si: 0.60%
P+S: 0.04%
Cu: 0.20%
Cr: 0.80%
Mo: 0.40%
Ni: 0.30%
B: 0.007%
Ti: 0.20%
C equi: 0.50
Rm : 1100 - 1350 N/mm2 110-135 kg/mm2
A% 14
HB: 360-420
Wear Factor: 75
The welding process can be Tig, Mig-Mag or Covered electrode.
Wich can be the better filler metal acording to Lincoln or Esab catalogue?
Thank you.
Hi leihotikan,
The chemical and mechanical characteristics listed above correspond to a steel type RAEX 400 or HARDOX 400.
The best fillers metals for welding this grade of material are :
SMAW / MMA
ELGA P62 MR or ELGA P110
ESAB OK 48.00 or ESAB OK 78.16
FILARC 35 or FILARC 118
OERLIKON SUPERCITO or OERLIKON CROMACORD KB
GMAW/MAG
ELGA ELGAMATIC 100 or ELGA ELGAMATIC 135
ESAB OK AUTROD 12.51 or ESAB OK AUTROD 13.12
OERLIKON CARBOFIL 1 or OERLIKON CARBOFIL CrMo1
FCAW
ELGA DWA 50 or ELGA 110B
ESAB OK TUBROD 15.14 or ESAB OK TUBROD 15.09
FILARC PZ 6148 or FILARC PZ 6148
OERLIKON FLUXOFIL 14HD
MCAW (metal cored)
ESAB OK TUBROD 14.12 or ESAB OK TUBROD 14.03
FILARC PZ 6102
OERLIKON FLUXOFIL M8 or OERLIKON FLUXOFIL 36
The Heat Input must be less than 20 KJ/cm
The preheat temperature is 75°C / 150°C for a thickness exceeding 20 mm
The interpass temperature should be less than 200°C
Click on this hypertext link to see the English documentation HARDOX WELDING
Haga clic en este enlace para leer la literatura de ventas en español HARDOX SOLDADURA
Best regard.
is the same with Urssa 400?
Hi,
Yes, we are confident that the characteristics of URSSA 400 are identical to the steels HARDOX 400 or RAEX 400.
Best regard.
