IGOLDENCNC En ligne le 21/02/2025 à 07:01 (1 message sur soudeurs.com)
Sujet : VEnte Laser Robotic Welding Machine
21/02/2025 07:00:14
A robotic fiber laser welding machine integrates a robotic arm or multiple robotic arms to manipulate the welding process.Robotic fiber laser welding machines can be used to weld various metals, including steel, stainless steel, aluminum, titanium, and copper alloys. They are commonly used in industries such as automotive, aerospace, electronics, and manufacturing, where high-quality and efficient welding is required.
laser welding robot
Robot Laser Welding Advantages
  1. Process Monitoring and Control: Robotic fiber laser welding machines often incorporate advanced monitoring and control systems to ensure welding quality and process stability. These systems can monitor parameters such as laser power, welding speed, and weld quality in real-time. They may also include features like adaptive control to compensate for variations in material thickness or fit-up.
  2. Robotic System Integration: A robotic fiber laser welding machine integrates a robotic arm to manipulate the welding process. The robot arm(s) is programmed to position the workpiece and control the laser beam accurately, ensuring precise and consistent welding. This integration enables automation, flexibility, and the ability to weld complex geometries.
  3. Fiber Laser Technology: Fiber lasers use optical fibers to deliver the laser beam to the welding head. They are known for their high power density, excellent beam quality, and energy efficiency. Fiber lasers emit a concentrated laser beam that can be precisely controlled, providing high-quality and efficient welding results.
  4. Flexibility and Versatility: The robotic system in a fiber laser welding machine offers flexibility in positioning and manipulating the workpiece and laser beam. This allows for welding in various orientations, angles, and hard-to-reach areas. The machine can be programmed to perform different welding paths, joint configurations, and welding sequences, making it adaptable to a variety of welding applications.
robotic laser welding machine-08
Retour d'expérience database parametre soudage
02/04/2021 07:04:13 - raynald60
Affichages : 16
LoicJn
07/04/2021 07:46:10
Demande d’aide Soudage hélicoïdal mécanisé
12/03/2022 10:32:26 - WeldingCircus29
Affichages : 26
13/03/2022 16:10:06
Demande d’aide Problème de fil collé dans le tube contact sur application MIG Alu
08/01/2024 15:27:32 - JJ67
Affichages : 13
JJ67
08/01/2024 15:27:32
21/02/2025 07:00:14 - IGOLDENCNC
Affichages : 0
IGOLDENCNC
21/02/2025 07:00:14
